I'm working with a couple of demo apps provided by the S32K SDK version 0.8.6 EAR and I have got them to work in debug mode but no matter how I create the release configuration I cannot get the micro to run code in standalone mode that is just by powering the board!
Kindly, please, share the procedure to create a release candidate based on a demo app!
Thank you!
typically SDK examples doesn't have Release configuration - only Debug RAM and Debug Flash. If you need release version - you can set debug level NONE for Debug Flash target (right click on project name -> Properties -> C/C++ Build -> Settings -> Debugging
Flash this elf into EVB and press reset button on EVB. App should be running without any interaction with S32DS.
Jiri
