I get some error messages if I try to install the update. Please see attached file.
Some hints to fix the problem are welcome...
Jörg
已解决! 转到解答。
... I finally manged the update. I have disabled all URLs in "Available Software Sites" and then it works.
... I have switched off the firewall but no difference. Also my network connection is fine.
Other suggestions?
Hello Jörg,
I updated S32DS right now and have no issue with that. In your case it may be some temporary network outage or firewall issue on your network. If the errors are still present - check the firewall settings and network connection.
Jiri
never-displayed
