Hi All , I have some sample project for S32DS V1.2 ARM and I want to import it into S32ds V1.2 Power pc , I have tried , but it is always failing at the subdir.mk files
make: *** target pattern contains no '%'. Stop. subdir.mk
I'm afraid the migration form S32DS ARM into S32DS Power is not supported. I'd suggest you to create a new project in S32ds Power and transfer the source source files manually.
If you use S32 SDK you'd have to re-create project from scratch and add your custom code section into the new project.
Stan
