1. every time i open the SD32 it will auto check the updating, it's boring, i want to close it
2. it often occur a message "new module is availabe" in the right down corner of SD32 tool, but i don't want this update, i don't want this meesage aloways jump out
已解决! 转到解答。
Hi @Leo2
At the Window tab located on the main menu of S32DS, go to Preferences -> S32 Desing Studio for S32 Platform -> S32DS Extensions and Updates, there you can select if you want to open the updates window every time that you open S32DS or a certain time (once a day, a week or a month), or if you no longer want the window to open in the startup. Also, if you do not want to be notified if there is a new available update.
B.R.
VaneB
Hi @Leo2
B.R.
VaneB
