How do I enable Live View for variables when debugging?
7,966 次查看
davidklamer
I am working with S32 Design Studio using the S32K144EVB with the OpenSDA debugger.  I am trying to enable Live View for variables, where the variables in the watch window will update while the device is running.  However, I can't seem to find it.  Is there something I need to download or a setting I need to change to enable it?
I did some searching and found this article showing the P&E has a plugin for Eclipse.  I installed the latest PEMicro extension as suggested in the article, but it didn't seem to make any difference.
I used this feature all the time with CodeWarrior, and would like to use it for S32 Design Studio as well.  Any help would be appreciated!
标签 (2)
6,511 次查看
stanish
Hello David,
The Real Time Expressions View works with any PEMicro cable including OpenSDA interface.
The Live View feature is documented on pemicro PEMicro Blog
This view is not opened by default in the Debug perspective and you have to add it manually
Simply Go to menu Window -> "Show View" -> "Other..." and type "Real" into the filter field and select " Real Time Expressions"
The view should appear in the Debug perspective. Now if you add a variable and press "Resume" button (F8 key):
You should observe the variable is being updated.
If it does not work on your side please send us more details.
Thanks!
Stan
5 回复数
3,041 次查看
Srividhya1
how to export those real time expressions values @stanish  into text or excel any data.
2,958 次查看
stanish
I'm not aware of any way how to easily log the Real time variables into csv or excel format.
Please try to ask PEmicro | Experts in Embedded tools for Flash Programming and Development
Another approach to capture runtime variables is to use FreeMASTER tool. See the related NXP community here:
FreeMASTER - NXP Community
Hope it helps.
S.
6,513 次查看
martin_kovar
please read the article from PEMicro below. It explains how to setup S32 Design Studio.
PEMicro Blog
Martin
6,512 次查看
stanish
Hello David,
Thanks!
Stan
6,512 次查看
davidklamer
Thank you!  That is exactly what I needed, and is now working perfectly.
