I am using S32 Design Studio compile Mpc5744P , but it always appear a problem(Error with command: gdb --version Cannot run program "gdb": Launching failed)。 I use the S32DS version is V2.1 , could you tell me how to solve it , Thank you !
You can remove the "Run on reset" box. Then try again.
what's your project? It is an example or existing old one? Can you share it?
Jiri
