This is Kihoon Kim from Seoul National University of Science and Technology.
I have a question about S32 error.
How to solve this error??
Now I'm using S32 for Power Architecture, and MPC 5777 Development Board.
Error message is mentioned below.
Thank you.
Error in final launch sequence
Failed to execute MI command:
-exec-run
Error message from debugger back end:
Error creating process C:/Users/kihoon/Dropbox/[3]°úÁ¦/[0]Çö´ëÀÚµ¿Â÷ Single stage 11kW OBC/[3]MPC5777C/Workspace/Hyundai_NXP_220713/SNU_CMU_mpc5777c/Debug_FLASH/SNU_CMU_mpc5777c.elf, (error 193).
I am getting this same error . no space in the path
Error in final launch sequence:
-exec-run
Error creating process C:\Work\NXP\flexcan_encrypted_s32k148\Debug_FLASH\flexcan_encrypted_s32k148.elf, (error 193).
-exec-run
I have checked the permissions on the folder and I have full access/write access for the folder system ..
any thoughts. is there another folder it must write as well somewhere. that perhaps or which I do not have permissions.
Hi kihoon,
Can you please visit the following link and try the suggestion? Please removing spaces in your path.
https://stackoverflow.com/questions/1106930/cygwin-gdb-gives-error-193-when-trying-to-start-program
