masserase memory map
492件の閲覧回数
Neo_zhang
CW execute masserase, which part the memory has been erased?  both EEPROM and flash or just the flash ?
2 返答(返信)
475件の閲覧回数
stanish
Could you please specify the target MCU you are using?
In case it is S12(x) family there is an option to enable/disable erasing of EEPROM (go to File -> Configuration dialog - where you can specify which flash memory blocks should be erased:
If you use S12z the debug will erase just Program FLASH. in order to program EEPROM you should use Flash Programmer component (Target Task):
Hope it helps.
Stan
472件の閲覧回数
Neo_zhang
My target MCU  is MC9S12DT256, can I edit 0x000 - 0x3FF registers region and 0x1000 - 0x3FFF RAM and how to do it?
