Sleep mode in S12Z VCA192 controller.
1,326件の閲覧回数
dhankarcdas
I am trying to put the controller to sleep mode. In the data sheet it is given that U bit in CCR register has to be set and S bit has to cleared to go to sleep.
Currently we used "asm ANDCC #0x7F;" instruction which only clears the S bit.
ANDCC instruction access only lower 8 bit of CCR. But U bit is 15th bit od CCR.
How can we set the U bit in CCR?
The current sequence is
asm ANDCC #0x7F;
    asm STOP;
3 返答(返信)
960件の閲覧回数
MJW
clearing the S-bit is sufficient to enable the execution of the "STOP" instruction.
Setting the U-bit would actually disable both "STOP" and "WAI" instructions (both are executed as "NOP" if U-bit is set).
HTH,
MJW
960件の閲覧回数
dhankarcdas
Thanks for the answer. But in reference manual MC9S12ZVC Family Reference Manual Rev. 1.3, page 52 it is given that
"The U-bit should be set and the S-bit (stop enable) should be cleared in the
CPU condition code register (CCR) to execute the STOP
instruction.Otherwise the STOP instruction is considered as a NOP."
This makes the confusion.
960件の閲覧回数
MJW
The correct description is in the S12ZCPU RM:
http://cache.nxp.com/files/microcontrollers/doc/ref_manual/S12ZCPU_RM_V1.pdf
Look for the "STOP" instruction in "Instruction Glossary", for example.
("user state" refers to U-bit set, "supervisor state" to U-bit cleared).
So, this is an error in the S12ZVC RM.
I forwarded the issue to the S12ZVC RM owner to have this fixed in the next version.
Thanks for the notice.
MJW
