Problem with debug : step to step
1,049件の閲覧回数
chris69
I have a mc9s12dg256, when i run my program in debug and i want to do step to step (F10 for example) but all the times i do step to step i step into the OSTickISR !
SO i can't debug with step.
Can anyone, please, help me
604件の閲覧回数
CrasyCat
Specialist III
Hello
If you are using a P&E Multilink/CyclonePro cable for debugging, if you select entry Communication or Connect in the Multilink/CyclonePro menu you open the connection dialog.
Inside of the Special Setup or Debug option tab you should be able to  find a box "Disable maskable ISRs when stepping".
Check it and you should be able to avoid stepping inside of the interrupt functions.
CrasyCat
2 返答(返信)
605件の閲覧回数
CrasyCat
Specialist III
Hello
CrasyCat
604件の閲覧回数
chris69
thank you :smileyhappy:
