MC9S12ZVML128_BLDC_Sensorless example adding ADC measuring
1,654件の閲覧回数
subinkim
I want to use ADC module to get AMP0 and AN1_0 in BLDC_sensorless example code.
My codes are like this,
void initGDU()
 GDUE_GCSE0 = 1; // enable Current Sense Amplifier 0
void initGPIO(void)
 DDRADH_DDRADH0 = 1; /*AN1_3 set*/
 PTAD_PTADH0 = 1;
volatile short PTUTriggerEventList[PTU_TOT_TRIGGERs_GEN_NO][PTU_TOT_LISTS_NO][4] ={
  { /*DelayT0 */
    {0x0100, 0x0200, 0x0000, 0x0000}, {0x0000, 0x0000, 0x0000, 0x0000}
volatile char ADC0CommandList[6][4] = {
  { 0x40, 0xD0, 0x00, 0x00 }, // current sense channel, end of sequence [D0]
  { 0xC0, 0xCB, 0x00, 0x00 }, // end of list + no int [C0], HD voltage [CB], 4 clock cycles sample time [00], reserved [00]
  { 0x00, 0x00, 0x00, 0x00 },
  { 0x00, 0x00, 0x00, 0x00 } };
PR_SECTION(adcLists)
volatile char ADC1CommandList[6][4] = {
  { 0x40, 0xCA, 0x00, 0x00 }, // [end of list] + no int [C0], phase voltage [CA], 4 clock cycles sample time [00]
  { 0xC0, 0x50, 0x00, 0x00 }, // ADC1 AN1_0
volatile unsigned short ADC0ResultList[6] = { 0, 0, 0, 0, 0, 0 };
volatile unsigned short ADC1ResultList[6] = { 0, 0, 0, 0, 0, 0 };
void UpdateDutycycle(void) {
 tU16 delay1, delay2;
 PMFVAL0 = duty_cycle;
 delay1 = duty_cycle >> 2;    // middle of the pulse - DC Bus current
 if (delay1 < MIN_ADC_TRIGGER_FIRST)
  delay1 = MIN_ADC_TRIGGER_FIRST;
 PTUTriggerEventList[0][0][0] = delay1;
 delay2 = MLIB_Mul(duty_cycle,BEMF_SENSING_POINT_FRAC,F16); // end of the pulse
 if (delay2 < MIN_ADC_TRIGGER_FIRST)
  delay2 = MIN_ADC_TRIGGER_FIRST;
 PTUTriggerEventList[1][0][0] = delay2;     // ADC1 - phase voltage
 if (delay2 < (delay1 + MIN_ADC_TRIGGER_SECOND))
  delay2 = delay1 + MIN_ADC_TRIGGER_SECOND;
 PTUTriggerEventList[0][0][1] = delay2; // ADC0 second sample - DC Bus Voltage
 PTUTriggerEventList[1][0][1] = delay2+35;
 PTUC_PTULDOK = 1;
It looks like that the ADC values are measured, but the BLDC motor is not rotating normally(repeat stop and go).
what's the problem of my code?? I beg your opinion.
タグ(3)
4 返答(返信)
965件の閲覧回数
Monke
I have the same problem as you. This is my question.How to config ADC of MTRCKTSBNZVM128_CW11 - NXP Community
Like you, I have read a lot about ADC sampling, but there are no results. How did you solve it later?
1,274件の閲覧回数
528887301
Hi.
I use MC9S12ZVML128_BLDC_Sensorless example project.
Only to modify the current acquisition function from the operational AMP0 to the operational AMP1.
But it has never been successful, Is there an example here?
1,274件の閲覧回数
dianabatrlova
You can find discussion about this topic on the site below:
MC9S12ZVML128_BLDC_Sensorless adding ADC
Diana
1,274件の閲覧回数
subinkim
Thank you for your response.
I already read it before I upload the question. But it's now working on mine.
The motor repeats stop and go.
I think it is concerned with trigger timing.
(ISR or value of delay1/2 or UpdateDutycycle() function's TriggerEventList value setting
Please give me your more opinions.
