Hi Salman,
I assume, you already read the reference manual
Receive Data Register Full Flag:
RDRF is set when the data in the receive shift register transfers to the SCI
data register. Clear RDRF by reading SCI status register 1 (SCISR1) with RDRF set and then reading SCI data
register low (SCIDRL).
0 Data not available in SCI data register
1 Received data available in SCI data register
In case of master, the SCI TX and RX lines are connected to the LIN PHY.
When master sends data through TX wire, it will receive this data in RX wire and RDRF will be set. In another case when slave sends data in Lin Bus, RX wire of master will receive this data too and RDRF will be set.
I hope it helps you.
Diana
Hi Salman,
Diana
