Jump to bootloader through user app
Pinak
I want to jump to Bootloader through user appl. Do not want to use any IO port for that (i/p detect).
I tried by defining a non volatile var in RAM(by defining it as NO_INIT in prm). Then set that var before soft reset(COPCTL & ARMCOP). & check in startup in user app.  But after reset the user app. executes instead of Bootloader.
How to jump to Bootloader through User app.
sebasira
Senior Contributor I
Hi Pinak!
Maybe some extra data would help..
Wich MCU are you using?
And how do you declare that variable?
