Error using interrupt
751 次查看
kdn
I have attached error file which I am getting while using interrupt , can anyone please provide me solution for it.
标记 (3)
572 次查看
iggi
See the snapshot below. The ISR inside the pragma segment in CAN1.c source file must be available (out of comment; not in red)
You can use the following code inside the ISR to service the CANRx interrupt:
ISR(CANRxISR)
   unsigned char length, index;
    unsigned char rxdata[8];
    length = (CAN0RXDLR & 0x0F);
      for (index=0; index<length; index++)
          rxdata[index] = *(&CAN0RXDSR0 + index); /* Get received data */
    CAN0RFLG = 0x01;   /* Clear RXF */
Hopefully the info helps.
Regards.
iggi
