Debugger connection error
812件の閲覧回数
pratibhasurabhi
Contributor V
I am currently using codewarrior 10.7 on windows 10 - 64bit os.
I am not able to download the code using debugger on board S12ZVML128 MCU, i am attaching the snap of the error message which is popping everytime whenever i click debug button on codewarrior 10.7
I also Re-installed the CodeWarrior and tried to debug another workspace but still it is showing the same error message.
Suggest me method in order to fix this issue.
Thanks!
790件の閲覧回数
dianabatrlova
Have you checked the user guide of the board, power supply, jumper settings?
https://www.nxp.com/webapp/Download?colCode=MC9S12ZVM128MCBUG
When you check the connection in the debug configuration, have you seen the port?
For example:
Thank you,
Diana
