Current threshold and Ah counter threshold sample code
867件の閲覧回数
gumu
Hi NXP team,
I'm using RD9Z1-638 to develop BMS project.There is a demand that device can be woke up from stop mode by current threshold or Ah counter.
This is my code:
	u8 CAN_status[3];
	Sleep_CAN(CAN0, CMPTX);                           // request CAN channel 0 go to sleep with completing transmission scheduled
	do {
		Check_CAN_Status(CAN0, CAN_status);           // read the channel 0 status
	} while (!(CAN_status[1] & SLPAK));					           // wait till SLPAK bit set
	B_PCR_WUEH_WUPTB4 = 1; // enable PTB4 wakeup
	B_ACQ_CTH = 100;
	B_PCR_WUEH_WUAHTH = 1;  //Wake-up on Ah counter enabled
	B_GPIO_TSENSE = 0;
	B_GPIO_VSENSE = 0;
	ADCDisable();
	TsenseDisable();
	CAN_STDBY(STANDBYMODE);
	ApiRtcSetWakeupPeriod(RTC_PERIOD_WAKE_TIME);
	PCREnterStopMode();
 but it didn't work.
I'd like to know if there is sample code for this function!
Thanks!
タグ(1)
809件の閲覧回数
Q_man
The coulomb counter (CC) simply adds up every ISENSE ADC measurement. The frequency (interval) of the measurements in low power mode can be configured with the ACQ_TCMP register.
In the example:
The frequency is 10 samples per second 10S/s. The ADC typically has a resolution of 1mA per LSB. This results in a 0.1mA*s per LSB resolution for the CC.
The threshold of 60000 equals to 6000mA*s (e.g. applying 100mA for 60s should trigger the threshold)
3 返答(返信)
856件の閲覧回数
Q_man
To use any current sense based wakeup, the ISENSE channel must be configured and enabled in the Low Power mode. Here some example code:
ADCDisable();
TsenseDisable();
B_GPIO_VSENSE = 0;
IrqDisable();
// config to measure every 100ms in sleep
B_ACQ_TCMP = 100; // LP clock = 1KHz, depends on PF[1:0] setting
// config to wakeup if |I| > 500mA
B_ACQ_CTH = (500>>1);
B_ACQ_THF = 0;
// config to wakeup if Ah counter >xxx
B_ACQ_CTL = B_ACQ_CTL_AHCRM_MASK | B_ACQ_CTL_AHCR_MASK; // reset Ah counter
B_ACQ_AHTH = 60000L; // 100mA * 60s * 10S/s
ADCLpEnable();
PCREnterStopMode();
/*! \brief Enables CSENSE channel Acquisitions for low power modes.
void ADCLpEnable(void) {
B_ACQ_CTL = (B_ACQ_CTL_CMENM_MASK | B_ACQ_CTL_CMEN_MASK)//!< enable current sense measurements
822件の閲覧回数
gumu
Hi @Q_man ,
Thank you very much!
The sample code can work well. But I don't understand how to caculate the value of B_ACQ_AHTH ,
 what's the unit of B_ACQ_AHTH.
Thanks!
810件の閲覧回数
Q_man
In the example:
