We are using global address access for flashing application in S12XE controller projects.
Whether global address accessing can be used for flashing application in S12G128 controller?
Kindly answer my question.
Arthi Venkatasubramanian
On S12G derivatives, the global addressing can be used only for programming.
Because only the FCCOB registers accept global addressing.
BR, Daniel
I have one more question.
Why Global Address are not accessible while reading PFLASH in S12G128?
Whether it is mentioned in Datasheet. If so can you share?
