About sleep current on 9S12ZVL32F0MLC
460件の閲覧回数
binhuang
The circuit diagrams in my project in the attachment as picture 1, if set pin9 and pin12 as pull-up output, the sleep current of mcu is 20uA higher than which is set as pull-up input. Could you help to explain it. Thanks
R10 is equivalent to the internal pull-up resistance of MCU,other resistors are external components
0 返答(返信)
