ls1046a dpaa usdpaa_policy_hash_ipv4_1queue
633件の閲覧回数
hongyuanz
1queue can be configured, 2queue configuration failed   related documentation. . ?
root@localhost:/home/user# fmc -c ./usdpaa_config_ls1046.xml -p ./usdpaa_policy_hash_ipv4_1queue.xml -a
root@localhost:/home/user# fmc -c ./usdpaa_config_ls1046.xml -p ./usdpaa_policy_hash_ipv4_2queue.xml -a
ERR : failed to load external entity "./usdpaa_policy_hash_ipv4_2queue.xml"
621件の閲覧回数
yipingwang
Please use LSDK 21.08 Ubuntu main rootfs filesystem, which could be downloaded from the following link.
$ wget https://www.nxp.com/lgfiles/sdk/lsdk2108/rootfs_lsdk2108_ubuntu_main_arm64.tgz
Then use configuration files in /usr/local/dpdk/dpaa, I have verified the following commands, didn't encounter any error.
root@localhost:/usr/local/dpdk/dpaa# fmc -c ./usdpaa_config_ls1046.xml -p ./usdpaa_policy_hash_ipv4_1queue.xml -a
root@localhost:/usr/local/dpdk/dpaa# fmc -c ./usdpaa_config_ls1046.xml -p ./usdpaa_policy_hash_ipv4_2queue.xml -a
root@localhost:/usr/local/dpdk/dpaa# fmc -c ./usdpaa_config_ls1046.xml -p ./usdpaa_policy_hash_ipv4_4queue.xml
