fsl-image-kernelitb Error
2,859件の閲覧回数
mounikareddy22
I'm using yocto SDK 2.0, In which i'm trying to build Linux image for T4240RDB.
Following is the procedure followed:
1. bitbake -c menuconfig virtual/kernel
2. bitbake -c compile -f virtual/kernel
3. bitbake virtual/kernel
4. bitbake fsl-image-kernelitb
When i give "bitbake fsl-image-kernelitb",
"ERROR: Nothing PROVIDES 'fsl-image-kernelitb'
ERROR: fsl-image-kernelitb was skipped: incompatible with machine t4240rdb-64b (not in COMPATIBLE_MACHINE)" is displayed.
Could you please help me to proceed further.
Waiting for your reply..!
Thanks & Regards,
Mounika Reddy
タグ(1)
3 返答(返信)
1,466件の閲覧回数
Pavel
The T4240 u-boot does not supports .itb files. There is no the fsl-image-kernelitb.bbappend for the T4240.
Pavel Chubakov
1,466件の閲覧回数
Pavel
NXP SDK 2.0 does not support kernelitb for the T4240. This option is available for the LS1012a. LS1043a and LS1046a. See the following file:
QorIQ-SDK-V2.0-20160527-yocto/sources/meta-nxp-npi-1703/recipes-fsl/images/fsl-image-kernelitb.bbappend
Pavel Chubakov
1,466件の閲覧回数
mounikareddy22
Thank you for the reply..!
I have few more doubts:
1. Were I can download the fsl-image-kernelitb.bbappend ?
2. If I download and add the fsl-image-kernelitb.bbappend file to recipe folder will it work straight away or I need to do any changes?
Could you please suggest me the procedure?
Thanks & Regards,
Mounika Anugula
Design Engineer
Mobile : (+91) 9916711639
Website : <http://www.coreel.com> www.coreel.com
Ph: (+91)80-41970400
Fax: (+91)80-30723638
CoreEL Technologies,
#21, 7th Main, 1st Block , Koramangala,
Bangalore 560034
<https://www.facebook.com/CoreELTechnologies> Description: Description: Image result for facebook icon in orange <https://www.linkedin.com/company/coreel-technologies?trk=company_logo> Description: Description: Image result for facebook icon in orange
Description: COREEL~1 - Copy.JPG
