Hello everyone.I want to cross compile a software on my p1010rdb-pb board.I use the yocto v1.8 downloaded from official site.
I use 'sudo make install',compile is well,while there is something wrong with link.
However,when I link it by myself,it works.
How can I solve the problem when using 'sudo make install'?Thanks in advance for any help.
As I mentioned in another thread, I suggest you use the standalone toolchain as the following.
$ source /opt/fsl-networking/QorIQ-SDK-V1.8/environment-setup-ppce500v2-fsl-linux-gnuspe
$ ${CC} test.c -o test.out
Yiping
