T2080 MDIC[1:0] Discrepancy
554 次查看
neoventus
The T2080 reference manual states 187ohms should be used to bias the MDIO lines, while app note AN3940 states 40ohms. Can someone verify 187 is correct?
473 次查看
garymilliorn
Also note that MDIC sets the impedance of the DDR MDQ signals, not the EMI MDIO (I know that's not what you meant).
473 次查看
alexander_yakov
In case of any discrepancy between device data sheet and any other document, please trust device datasheet.
In this case, AN3940 is common appnote for devices with DDR3 controller starting from MPC85xx (note - this appnote is not listed at T2080 documentation page), whereas T2080 device datasheet contains MDIC values specific for this particular processor.
Alexander
