Hi all,
I manage to run U-Boot from SPI flash by flashing the Yocto SPI uboot at the corresponding partition:
flash_eraseall /dev/mtd11
cat u-bootSPI.bin > /dev/mtd11
However, I have some problems as U-boot runs the ramdisk image that has been successfully tftped at an address. At one point, the system hangs. Here is the log
U-Boot 2011.12-00064-gbfb0c9a (Nov 15 2012 - 23:28:50)
CPU0: P1021E, Version: 1.1, (0x80ec0111)
Core: E500, Version: 5.1, (0x80212051)
Clock Configuration:
CPU0:800 MHz, CPU1:800 MHz,
CCB:400 MHz,
DDR:333.333 MHz (666.667 MT/s data rate) (Asynchronous), LBC:25 MHz
QE:400 MHz
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Board: P1021RDB CPLD: V4.1 PCBA: V4.0
Error reading i2c boot information!
I2C: ready
SPI: ready
DRAM: DDR: failed to read SPD from address 82 :smileyalert:
Error in DDR bus width configuration! :smileyalert:
16 MiB (DDR3, 32-bit, CL=6, ECC off)
Flash: 16 MiB
L2: 256 KB enabled
NAND: 32 MiB
MMC: FSL_SDHC: 0
SF: Detected S25FL128P_64K with page size 64 KiB, total 16 MiB
Firmware 'Microcode version 0.0.1 for P1021 r1.0' for 1021 V1.0
QE: uploading microcode 'Microcode for P1021 r1.0' version 0.0.1
PCIe1: Root Complex of mini PCIe SLOT, no link, regs @ 0xffe0a000
PCIe1: Bus 00 - 00
PCIe2: Endpoint of PCIe SLOT, no link, regs @ 0xffe09000
PCIe2: Bus 01 - 01
In: serial
Out: serial
Err: serial
Net: eTSEC2 is in sgmii mode.
uploading VSC7385 microcode from ef020000
PHY reset timed out
eTSEC1, eTSEC2, eTSEC3
Hit any key to stop autoboot: 10 0
=> run ramboot
Speed: 1000, full duplex
Using eTSEC1 device
TFTP from server 10.a.b.c; our IP address is 10.d.e.f
Filename 'rootfs.ext2.gz.u-boot'.
Load address: 0x2000000
Loading: *#################################################################
done
Bytes transferred = 28954008 (1b9cd98 hex)
Using eTSEC1 device
Filename 'uImage-p1021rdb.bin'.
Load address: 0x1000000
done
Bytes transferred = 3620878 (37400e hex)
Using eTSEC1 device
Filename 'uImage-p1021rdb.dtb'.
Load address: 0xc00000
Loading: *##
done
Bytes transferred = 25245 (629d hex)
## Booting kernel from Legacy Image at 01000000 ...
Image Name: Linux-3.0.34-rt55-02404-g1a39570
Created: 2012-11-30 13:55:59 UTC
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 3620814 Bytes = 3.5 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 02000000 ...
Image Name: fsl-image-core-p1021rdb-20121116
Created: 2012-11-16 9:09:58 UTC
Image Type: PowerPC Linux RAMDisk Image (gzip compressed)
Data Size: 28953944 Bytes = 27.6 MiB :smileyalert:
## Flattened Device Tree blob at 00c00000
Booting using the fdt blob at 0x00c00000
Uncompressing Kernel Image ... OK
ERROR: Failed to allocate 0x1b9cd58 bytes below 0xffffffff.
ramdisk - allocation error :smileyalert:
Then, the system hangs here
It seems like I can't load the 27MB Ramdisk file using SPI-Uboot. Is it due to the DDR Configuration in the Uboot.bin file? Wrong DDR Bus Width configuration??
What should I do to fix this?
Where in the Yocto build source / Uboot source can I change the DDR Configuration? What kind of change?
Please Help!
Thank you very much!!
已解决! 转到解答。
SPI uses the on chip rom to configure DDR and should NOT be using SPD in u-boot. So I'm not entirely sure what's going on - but how did you produce the u-boot image you are trying to load?
Thanks very much for your replies!,
I built this U-boot using the Freescale Yocto SDK.
I had to disable the relevant configs: CONFIG_SPD_EEPROM and CONFIG_DDR_SPD in the U-boot sources.Then the board was able to boot properly using SPI-FLASH.
Thanks very much!!
It's a problem with DDR config: https://community.freescale.com/thread/302390
When I suggested posting a new thread about the DDR issue, I was expecting it to actually be about the DDR issue...
