LS1046A Hyperlynx simulation - pin vs die
468件の閲覧回数
BarryD
I'm simulating the ddr4 interface from the LS1046A to 5 dram chips using Hyperlynx.  Hyperlynx gives you the option of choosing pin or die.  I see different results when I try each.  Which should I use? Does your ibis model support simulating at the die or is it only valid for pin?
445件の閲覧回数
SebastianG
Hello @BarryD,
You should choose the pin option, the Ibis model is valid only for the pin simulation.
