LS1043A JTAG Programming Connection
1,044件の閲覧回数
logeshs
We are using LS1043A. I kindly request you to suggest us
1. what programmer should be used for programming LS1043A?
2. Programmer's operating Voltage level
3. Mating Connector part number of that programmer so that we can use it in our board.
4. Also if you have any datasheet for the programmer i request you to share the same to us.
Thanks.
6 返答(返信)
814件の閲覧回数
ufedor
The request is not clear.
What exactly do you mean by "programming LS1043A"?
Which board is in question?
814件の閲覧回数
logeshs
The question is about JTAG Configuration Signals Connector, Standard Cortex Debug Connector given in Figure.99 of LS1043A datasheet.
814件の閲覧回数
ufedor
The header part number is Samtec FTSH-105-01-L-DV.
Other questions about "programmer" still are not clear.
Do you mean "debugger"?
If "yes", then refer to the following links:
CodeWarrior ARMv8 64 bit|NXP
CodeWarrior TAP|NXP
814件の閲覧回数
logeshs
Yes, I mean about Debugger.
814件の閲覧回数
logeshs
As per Figure.100 in LS1043A datasheet VDD is connected to 1.8V. Please confirm does the debugger supports/operates in 1.8V?
814件の閲覧回数
ufedor
CoreWarrior TAP supports JTAG operation at 1.8V.
