How to find the flavour of your kernel ?
858 次查看
sarathchandra
Hi all,
           I am using Yocto SDK1.4 for my QorIQ processor.
           When I am giving "uname -a" it is throwing like "Linux p1023 3.8.13-rt9-QorIQ-SDK-1.4 #3 SMP ${date} ppc GNU/LINUX".
           Here does the "QorIQ-SDK-1.4" is the flavour ?
           else kindly let me know.
Thanks & Regards,
Sarath
标记 (2)
672 次查看
yipingwang
Hello Sarath,
The label "QorIQ-SDK-1.4" is Freescale Linux SDK flavour, actually in SDK it is called local version, you could find it is recorded in the file .scmversion in the Kernel source folder after configured by Yocto.
If you wan to modify this OS release version information, you could modify Kernel recipe, please edit the following code in Kernel recipe meta-fsl-ppc/recipes-kernel/linux/linux-qoriq-sdk.inc.
#add git revision to the local version
if [ "${SCMVERSION}" = "y" ]; then
       # append sdk version if SDK_VERSION is defined
       sdkversion=''
       if [ -n "${SDK_VERSION}" ]; then
           sdkversion="-${SDK_VERSION}"
       fi
       head=`git rev-parse --verify --short HEAD 2> /dev/null`
       printf "%s%s%s" $sdkversion +g $head > ${S}/.scmversion
fi
Yiping
672 次查看
sarathchandra
Thanks a lot Wang.
673 次查看
yipingwang
Hello Sarath,
       sdkversion=''
       fi
fi
Yiping
