Demos for T1040D4RDB-PA
1,265 次查看
walter95
Hi, this is my first time using nxp T1040D4RDB-PA and i'm looking for demos to help me understand how the board works.
Thank you
5 回复数
1,261 次查看
bpe
All available software for T1040 can be found in NXP QorIQ SDK:
https://www.nxp.com/design/software/embedded-software/linux-software-and-development-tools/linux-sdk...
Platon
1,259 次查看
walter95
I am installing QorIQ SDKV1.8 on Ubuntu and getting following error while executing host-prepare.sh:
could not find "libbonobo2-common"
fail to install pkgs on host
1,241 次查看
bpe
SDK 1.8 was only tested with Ubuntu 14.04. It may fail if you attempt to install it on a later version. If you are installing on Ubuntu 14.04, and there are still error messages, check this post for more suggestions.
Hope this helps,
Platon
1,235 次查看
walter95
I solved it by installing ubuntu 14.04. But after I installed the SDK, where do I find some bare metal examples (i.e. without an operating system) to be tested on the board?
1,207 次查看
bpe
No bare board software demos are available for T1040, sorry. If you are looking for a reference code to bringup and control a peripheral, you can look at Linux drivers:
https://docs.nxp.com/bundle/GUID-39A0A446-70E5-4ED7-A580-E7508B61A5F1/page/GUID-08616F56-1369-47B0-B...
Platon
