Use procesor expert default problem
760件の閲覧回数
marceladueñas
Hello everybody, i try to update to kds 3.2 and sdk 2.0 , a terrible idea because now all my projects have the next issue:
ERROR: at line 1: {{DEVELOPMENT}} The symbol "UseProcessorExpertDefault" was used without testing %ifdef or %if defined(). It's recommended to use %get() instead (if possible). (file: Beans\CriticalSection\CriticalSection.chg) V3 CS1 Processor Expert Problem
i try to comeback again , i uninstall all and comeback to the 3.0 version but the issue is the same , an even if i choose freRtos or procesor expert there is an error . I don't know what more can i do. HELP!!!
544件の閲覧回数
BlackNight
Hi Marcela,
make sure you have this setting disabled:
I hope this helps,
Erich
2 返答(返信)
545件の閲覧回数
BlackNight
Hi Marcela,
I hope this helps,
Erich
544件の閲覧回数
marceladueñas
You are so brilliant!!, it solve all the errors and warnings.
Thank you so much.
