Issue with USB 4.0.3 CDC example
1,190件の閲覧回数
pedropol
I used the example from  Freescale USB Stack v4.0.3\ProcessorExpert\Examples\Device\CDC\USB_CDC_DEVICE_JF128_PEx to make a CDC device with a TWR-MCF51JF128.
The example work fine when TWR receive a byte from UART and send to USB using
status= USB_Class_CDC_Interface_DIC_Send_Data(CONTROLLER_ID, g_curr_send_buf,size);
with size=1
but when size =16 no one byte is sent.
status result is USB_OK .
g_curr_send_buf seems set in queue
Callback function returns 216 bytes sent", but nothing is transmitted by USB
Reception works fine with 16 bytes.
Anyone knows what could be happening?
I need send AES encrypted data in 16 bytes blocks
940件の閲覧回数
BlackNight
I had reported this a while back too, and have made my own fix.
see http://mcuoneclipse.com/2012/04/17/fsl_usb_stack-updated-sending-16-or-32-byte-blocks/
There might be another issue: do not send a packet while one is still in transaction: this might fail especially if you send things fast. I have fixed this on my end too.
2 返答(返信)
941件の閲覧回数
BlackNight
940件の閲覧回数
pedropol
Thanks, I have the same problem. Messages with 16 bytes are not sent, but your fix doesn't works in my code. Finally, I divided the message in 2 messages with 8 bytes each one.
