Input Capture on jm128
775件の閲覧回数
carlospalma
Hello everybody, I'm working on a project which requires using HC SR04 ultrasonic
ranging module, but I'm stuck using the sensor since I can't seem to make the
Input Capture work using processor expert. So far I have used this:
void Cap1_OnCapture(void)
  /* Write your code here ... */
if(Cap1_GetCaptureValue(&pulse)==ERR_OK)
  Bit2_NegVal();
  Cap1_Reset();
so if an event of getting the value of the timer when an edge is detected occurs, a Led is supposed
to change its state. Problem is that even though the Led blinks, when I try to see the value of the
variable pulse using a serial communication, I get its initial value (200) in this case, which means that the
event didn't change it!
Any help would be greatly appreciated.
421件の閲覧回数
carlospalma
Well, I am in the way of  solving this and wanted to share my advances. As I said before for some reason the serial communication of the value acquired by the function Cap1_GetCaptureValue showed always 0. So I changed the routine to be this:
pulse=TPM1C2V;
Bit2_NegVal();
and boilá!, now when I use a PWM signal as the input to the Input capture and configure it to both edges, if I select the pulse width to be 50 us, I get 51 from the serial communication. (it gets the pulse width correctly), I have tried different values in microseconds and the value is always close (100-106), however the led is blinking oddly, many times more than it should.
