Flashmagic does not program
1,262 次查看
MVWare
Hi, I developed a board with the NXP LPC55S69. I have already developed a program with the Xpresso IDE.
My applications runs fine with the Segger Jlink on the SWD port.
I added the USB connection on USB1 of the device in the design.
I installed latest Flashmagic: 13.50 build 6367, it has USB driver 3.02 on windows 10
I enable the ISP with a jumper. Connect the USB ; from PC to my board. (Which also powers my PCB)
I folowed the setup of flashmagic: select USB LPC55S69. A hex file.
Device LPC55S69 (USB, LPC5500)
Interface tiegf6JWnvo5 (USB Bootloader)
   reading Signatures works.
   reading sectors works
   erasing sectors works.
But programming works not: (pressing START)
LPC55S69(USB, LPC5500) Operation Failed. (programming - failed to send data to the device)
In the Preferences:
hardware tab shows the UART selection bullets (as if the programmer will use UART? )
other tabs are default.
What is going wrong here? or do I do somthing wrong?
I enables debug mode, but can not find the debug file.
7 回复数
1,218 次查看
RaRo
Hello @MVWare,
Could you please take a look to the following information?
Also, may be useful to try the following recommendations:
Let us know if any of this helps you.
Best regards, Raul.
1,213 次查看
MVWare
Hi Paul,
So I woulkd like to conclude that the ISP interface is communicating.  right?
Afterthis, programmig does not work...
Is flashmagic still alive? That forum is quite dead.
1,208 次查看
MVWare
next update:
So On my board with LPC55S69 the flashmagic ISP works on UART.
It does not work on USB1,  although signature, read and erase works fine.
On the 55S69 NXP Eval board:  exactly the same behaviour!
On USB the flashmagic crashes very often. just exit at once.
Is flashmagic supported somewhere?  by NXP?  The site it's self does not reactot any forum question.
BLHost seems not very practical.
1,209 次查看
MVWare
In the mean time:   ISP with flashmagic on the UART port works.
1,182 次查看
RaRo
Hello @MVWare,
As you mention, ISP communication is working, but FlashMagic is failing at programming. This issue should be reviewed by FlashMagic team, please try to contact them through this way: Contact Support - Flash Magic, since you do not have success in the Forum.
As a recommendation, you could try and use our MCU Secure Provisioning Tool, we test the LPC55S69 EVK for uploading a binary trough USB1 and works.
Best regards, Raul.
1,163 次查看
MVWare
Hi Raul,  thanks for helping.
Does this MCU SPT work on  the ISP of the LPC55?
I don't read any thing about ISP in this tool...
in the mean time i'm still waiting for flashmagic support aswell...
1,159 次查看
RaRo
Hello @MVWare,
Yes, MCU SPT work on ISP for the LPC55xx. The compatible devices list is at the following link: MCUXpresso Secure Provisioning Tool | NXP Semiconductors.
[MCUXpresso Security Provisioning Tool List of Supported Devices]
Also, there you may find the MCUXpresso Security Provisioning Tool User Manual, which might come in handy if you decide to use the tool: MCUXpresso Secure Provisioning Tool User Guide v.5. In here it mentions the possibility and use of ISP in the supported devices.
[MCUXpresso Security Provisioning Tool User Manual. Section 6.1.5. Connection]
Best regards, Raul.
