MPC8641D+DDR2 ECC enabling
654件の閲覧回数
rekham
Hi I am new to developing a board with MPC8641D with enabling DDR2 ECC.
   My question is We are designed our customized board using power pc MPC8641 processor with DDR2 ecc as in document MPC8641DRM-pg no 8-49(415), and enabled ECC in DDR SDRAM Control Configuration (DDR_SDRAM_CFG). But my board was not booting with ecc. without ecc its booting. I am missing anything regarding this DDR2 ECC, please let me know is there any problem with my code.
Is there any problem while booting with this ECC. please let me know procedure for this
517件の閲覧回数
r8070z
There may be hardware problem on the ECC byte lane or ECC memory was not properly initialized. After power-on the ECC DDR memory does not contain valid ECC syndromes. Hence read access from uninitialized ECC memory will raise ECC error. Notice that 32-bit write access also starts from read. Preferable way of ECC memory initialization is DRAM data initialization enabled by D_INIT. ECC is correctly generated and stored during the DRAM data initialization when D_INIT is set.
2 返答(返信)
518件の閲覧回数
r8070z
517件の閲覧回数
rekham
thank you its working after enable the D_INIT.
