I am using FS6500 series SBC on safe mode. When I give signal from IO_O wake pin, my system can be awake but after 1-2 second automaticaly goes to down. Maybe go to LPOFF modes.
How can ı take diagnostic where ı am make wrong configuration or where is the mistake?
My configuration are listed below.
Select resistor is 24 k and connected to GND.
FS0B pin connected to MCU with pulled up by 10K to VSUP3
I am thinking the SBC can go to WAKE-UP phase on main state machine but after 1- 2second go to LPOFF mode a thing happened.
Maybe this issue about watchdog timer.. I don't know.
*Note : I can see the required all voltage level when ı give signal from IO_O in a period of 1-2 second.
Alican OZPAY
R&D Engineer
