Im struggling to find a way to change the jffs2 erase block size and page size in the freescale yocto SDK.
I have to do that because when I boot the kernel image from nand Flash, i get :
jffs2_scan_eraseblock(): magic bitmask 0x1985...
Any idea?
Many thanks
解決済! 解決策の投稿を見る。
I'm solved
I changed
./ltib -m config
Target Image Generation > Options > selected Target image: jffs2
(128) jffs2 erase block size in KB (org : (512) jffs2 erase block size in KB )
(2) Page size (max data node size)(Kbytes) (org: (4) Page size (max data node size)(Kbytes) )
My Nand driver setting checked
> mtdinfo -a
Eraseblock size: 131072 bytes, 128.0 KiB
Sub-page size: 2048 bytes
good bye
I'm solved
I changed
./ltib -m config
> mtdinfo -a
good bye
Try to change the "JFFS2_ERASEBLOCK = "0x..."" in meta-fsl-ppc/conf/machine/p2020rdb(your board).conf.
Thanks!
