the INH PIN of TJA1145
CaoRq
Hi,NXP
    when I put TJA1145 into sleep mode and pull down VCC and VIO , the INH pin should be low;
    but I meet a problem :the INH pin will experience the process of  low - high - low
    Can you tell me how to solve it?
    Thank you in advance
guoweisun
你能抓一些波形吗?INH 或者VCC/VIO。在INH 变化的时候做了些什么?
CaoRq
guoweisun
是不是中间又被唤醒了?
CaoRq
中间没有被唤醒,设定的特殊帧唤醒,没有发送can,WAKE脚是接地的
