any difference between SJA1124AHG/0Z and SJA1124AHG/1Z?
sebastian-uchman
Does anyone know the difference between this two?
pavla_hajna
Dear Sebastian Uchman,
Design changes SJA1124xHG/0 and SJA1124xHG/1
Two IP blocks were adjusted:
• The under voltage VIO timer
− The under-voltage recovery time of this timer was increased to match the MFIO start-up time
As a result, the MFIO output is well defined
• The main state machine
− The boot time was increased to match the MFIO start-up time.
Both changes were only changes in digital.
Important note - The new SJA1124AHG/1Z and SJA1124AHG/0Z are pin-to-pin compatible and software compatible (drop-in replacements).
Have a nice day. Best regards
Pavla
