Waking up external MCU
chiheb001
How to wake up an external MCU with OM25180FDK ?
Fabian_R
Thank you for letting us assist you in creating your solution.
Unfortunately, OM25180FDK is only a front-end device that requires an MCU for being used. If you would like to use an all-in-one solution, please check PN7462 where you will be able to write your application using MCUXpresso. Please check our NFC Reader Library, which I can assure you will be very helpful for starting with your project.
If you already have the OM25180FDK, will encourage you to also use the Reader Library with an additional MCU.
Fabian
