VR5510 OTP
VR5510 OTP
ajnas-c
Anyone please let me know the procedure for OTP on VR5510 PMIC? Is this programming done by I2C via a microcontroller, or is there another method?
diazmarin09
Hello Ajnas,
You are correct, the debug mode allow you, via the I2C interface, to access the OTP register set and modify them.
I hope this information helps.
David
diazmarin09
I hope all is great with you. Thank you for using the NXP communities.
In this case, you need Entering Debug mode.
The VR5510 provides a means of evaluating the device in Debug mode. Debug mode allows users, via the I2C interface, to access the OTP register set, modify the registers, and test device functions.
Please find further information at chapter 8.12 from datasheet.
David
ajnas-c
Hi David,
Good Day!
In the debug mode, I can change the register values using the I2C interface, right?
Ajnas
diazmarin09
Hello Ajnas,
David
