Temperature Cycling (TC) use ic or pcb?
493 次查看
jingfang
NXP through the automotive grade certification products,Temperature Cycling use IC or PCB?
486 次查看
guoweisun
This should be reliability test which test in PCB mounted the IC according the request of JESD22.
487 次查看
guoweisun
483 次查看
jingfang
The guest is asking if there is documentation?
