The BCM (MC33771CTP1AE) in sleep mode
Does above sequence is ok for generate the wake up sequence in TPL bus for MC33664A
Solved! Go to Solution.
the time between the so call wake-up pulses needs to be exact:
The first pulse wakes up the device and starts a timer. If the second pulse is not received with the 500-700us the device considers the first pulse as "noise" and goes back to sleep.
The 2.6ms from your scope definitely violates this and the device will not wake-up properly.
For further details please see MC33771C datasheet Rev 6.0 - chapter 10.2.6.2. Pack controller system wake-up.
Rgds
W.
Rgds
W.
