I found in an other thread
http://www.freescale.com/faqdata/FAQ-19720-SRC_BCK_ALPHA21.zip
where the sourcecode from flash over jtag V2 to be found.
But the link is down (freescale???).
I Need the source to generate a new programmer for actual Windows versions, or an embedded programmer for the DSP56f803 and DSP56f8346.
From the version 1 (flash_over__jtag.exe) the source where in the SDK from motorola, but there i
get only "device busy" because this version doesn't have the "-w" option and now i must know what makes this option in the source code.
Had anyone the source which i can get,
thanks very much.
Solved! Go to Solution.
Hi, Sven Grünbacher,
I attach the source code for the flash over jtag code for DSP56800E core, hope it can help you
XiangJun Rong
And what about 56F8322 ? Is possible to use ?
Sorry,
but this one is not for DSP56f8346 (E core).
I need the source from FAQ 19720.
Did anyone have this FAQ?
Kind regard
Sven Grünbacher
Hi, Sven,
Unfortunately, I have not the source code of flash-over-jtag for MC56F8346. As you know that the MC56F8014 uses the 56800E core, the same as that of MC56F8346.
Hope it can help you
XiangJun Rong
Hallo XiangJun Rong,
thank you,
i will try it.
I look in the datasheet of 56f801 and this one is the normal core.
Regard
Sven Grünbacher
Thank you very much,
that is what i search.
Kind regard
Sven Grünbacher
