[SLN-SVUI-IOT] Is `sln_svui_iot_r2.zip` support only MCUXpresso 11.8.1 ? and VIT
已解决
跳至解决方案
50 次查看
bryan_hong
Contributor V
dear qct
I use MCUXpresso IDE v11.9.0 now.
so Can Above work without any issue on MCUXpresso IDE v11.9.0 ?
Is it absolutely necessary to use MCUXpresso 11.8.1 and MCUXpresso RT1060 EVKB 2.14.0 SDK ?
and
When I get `VIT_Model_en.h` the  using VIT(https://vit.nxp.com/), How do I apply this file? Is there any documentation for it?
Bryan
1 解答
20 次查看
diego_charles
Hi @bryan_hong
I appreciate your interest on our voice solution projects.
In theory, you should be able to use MCUXpresso IDE v11.9.0. For first time evaluation I recommend using the SDK version used for the relase of a project, if everything goes well, you can migrate to a latest SDK version. If you are getting any troubles feel free to let us know.
Regarding the integration of the VIT_Model_en.h. Please refer to the How to integrate the new model in sln_svui_iot_local_demo? section of the SLN-SVUI-IOT User Manual.
Thank you for your patience, I hope this helps!
Diego
Diego
在原帖中查看解决方案
2 回复数
21 次查看
diego_charles
Hi @bryan_hong
Diego
Diego
2 次查看
bryan_hong
Contributor V
thanks for your helps~
