how can a customer find the revision of an SJA1110A?
There is a document "PR639710-SJA1110 Silicon Revision Tracker(1.0).pdf", but this document talks about Assembly codes: "19xx", "20xx", 20yy and 21zz".
Customer however has an assembly code "2210", which is not covered by the Tracker document.
What revision is the "2210" device?
Josef
Solved! Go to Solution.
Hi Josef,
see feedback I got from Apps team
"2210 assembly code is Rev. C. Please find an updated table below."
BR, Petr
Hi Josef,
BR, Petr
