SC16IS762 problem
SC16IS762 problem
1,017件の閲覧回数
wangliang
Hello :
I am using sc16is762 .
I use a serial tool send 90 bytes one time.
It happend sometimes that   the data read from spi  RHR register do not update.
The fifo rx level  read  rxlen = sc16is7xx_port_read(port, SC16IS7XX_RXLVL_REG);
it is 0x40 ,show that the fifo is full.
But I use  this function to read the fifo
  regmap_raw_read(s->regmap, SC16IS7XX_RHR_REG,  s->buf, rxlen);
But the fifo still the same ,it do not update again.but I only send 90 bytes.
If I read the fifo ,the fifo should cleared,It seems that the chip is halt .
Does anyone know how to fix it ?
wangl
0 返答(返信)
