Reg: CBTU02043HEJ
Reg: CBTU02043HEJ
651 次查看
chanmou
Iam using the Part No: CBTU02043HEJ.
My question is it acceptable to interchange the P & N of the channel .
I have a MIPI-DPHY-Data P&N passing through this. Can i feed P to the N channel and N to the P channel , as it helps to avoid trace crossover on the layout
642 次查看
TomasVaverka
Hi Chandra,
Yes, there is no problem to use the CBTU02043HEJ the way you are intending.
Tomas
