we have a project where a PTN3460I is connected to an Intel Arria 10 FPGA via the LVDS output ports. To enable the use of DPA on the FPGA LVDS inputs a training pattern (or known pattern) is required from the source. Is there any way to setup a custom or training pattern from the LVDS outputs on the PTN3460I?
Oddgeir
Solved! Go to Solution.
Hi Oddgeir,
The PTN3460I does not support any custom or training pattern from the LVDS outputs.
Tomas
Hi Oddgeir,
Tomas
Hi Tomas,
thank you for the reply. We will work around it some other way.
Oddgeir
