Hi we are working with a military Head Worn Display which requires 600x800 VGA converted from
DP++ using the PTN3392BS on our processor reader board. We are having trouble forcing low res VGA to the display due to the lack of I2C signalling. Other eader boards we make can do this utilising a second vendor adaptor changing onboard DP++ to VGA.
Do you have the latest firmware version for the PTN3392BS and directions on how to flash it.
Thanks for your help...Andrew
Solved! Go to Solution.
Hi Andrew,
Unfortunately, firmware (or details about it) for the PTN3392 cannot be shared without a signed NDA, you may need to contact your NXP sales representative to get such information. However, it is guaranteed that the part number PTN3392BS/F4Y contains the latest version of the firmware (Firmware 4.0).
Jose
Hi Andrew,
Jose
