I'm using NXP's PCA9540BDP,118 and want to confirm what my VDD needs to be for a voltage translation from 3.3V master to 1.8V slave devices.
If my pull-ups on SDA/SCL is 3.3V and my pull-ups for SDA0/1 and SCL0/1 are 1.8V then my VDD needs to be 1.8V and can't be 3.3V. Is this correct? Am I interpreting the datasheet correctly?
<![if !vml]>
Jay
Solved! Go to Solution.
Yes,you are correct.
