Question related to NFMI coil simulation kit NxH2281
why do we place ferrite sheet as attached image on NFMI chip, communication distance will be reduced?
The ferrites sheet we used is DMR95 that is low loss material according to datasheet.
https://fericor.com/uploads/fericor/public/document/32-dmr95_low_loss_high_ui_power_material_sl.pdf
As you might know, there are some of the documents and libraries which are under NDA (Non-Disclosure Agreement) the information it's not public, the NXH2281 is one of this parts.
If you are already working with the NXH2281 , I believe you should already have a contact that helped you getting the information, could you please contact that person for further support on this part ? If you do not have one that contact, could you please contact one of our distributors available in the Distributor Network|NXP to help you with your request?
Estephania
