MPC5605 SPI Master use DMA
914 次查看
卓儒陈
I want to use DMA to transport data between RAM and a SPI device, and the MCU is the SPI master. I read "an4147" document and demonstration code, and I think it just use four DMA channel to simulate a SPI controller. I read the MPC5605 datasheet, and I understand that DMA can be triggered by internal SPI controller through TFFF and RFDF. Do I understand this correctly? Can you provide a demonstration code or some guide as detailed as you can, thank for your help.
681 次查看
lukaszadrapa
take a look at attached examples.
Lukas
682 次查看
lukaszadrapa
Lukas
681 次查看
卓儒陈
Thank you very much, I think they are very useful to me.
